Crankshaft position sensor location
254,852 MILES • 3.6L • V6 • AUTOMATIC
SATURNOWNER2.0
I need to change the crankshaft position sensor and I cannot for the life of me find the location on the motor. I have Googled until I have found a million different places and just don’t want to start unplugging and doing unnecessary work. please help.
Nov 1, 2021 at 1:52 AM
I will attach the info below from the manual. Here are a couple guides that will help with this:
Below you will see the info from the manual that will help with exact location and process to replace it.
It is on the back side of the motor and it easiest to access from underneath.
Please let us know what other questions you have. Thanks
Nov 1, 2021 at 9:07 AM
SATURNOWNER2.0
Thank you. replaced it today and it started throwing the code for the throttle body, so we took it off cleaned it really good thinking that would make it turn over, but no luck. so, looks like we will be replacing the throttle body next.
Nov 1, 2021 at 12:14 PM
Okay. Sounds great. If you need help with the throttle body issue, then feel free to get a post started for that issue and we will be able to help figure it out. We need to keep each post to one topic so that others can find it if they have the same one.
Let us know what happens and we can go from there. Thanks
Nov 1, 2021 at 12:39 PM
