Crankshaft position sensor location?
149,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
SENSORSEACH
I just need to find the exact location of the crankshaft position sensor on the car listed above LT model with a 2.4l Ecotech engine.
Jul 12, 2025 at 2:26 AM
  • 55,746 POSTS
You will need to remove the starter before you can get to the crankshaft sensor so disconnect the battery before you begin, also the sensor will need to have the relearn procedure before the engine will start. The sensor is on the lower part of the engine block on the left side back by the bell housing of the transmission. Check out the images (below). Let us know if you need anything else.
Jul 12, 2025 at 11:45 AM
SENSORSEACH
Thank you for the answer. Now I replaced the sensor and done the relearn procedure and all is as it should be.
Jul 13, 2025 at 3:23 AM
  • 55,746 POSTS
Good job! Please use 2CarPros anytime we are here to help.
Jul 13, 2025 at 5:36 AM
