crankshaft position sensor issue
120,000 MILES • 2.2L • 4 CYL • TURBO • 2WD • AUTOMATIC
BARSKY
My car shutdown once in a while so I diagnosed it with my scanner
and my tool showed the crankshaft position sensor is one of the problem.
actually they're 3 different issues.
the two is camshaft position sensor and intake runner control valve.
my concern is, there is no gear learning (relearn) process in the vehicle listed above. is there anyone here tried to do without gear learning process with your scanner?
share me if there is someone did it and doing good the car after it was made.
Sep 1, 2021 at 7:01 PM
  • 110,248 POSTS
What has been replaced which requires a relearn procedure? Also, can you provide the codes so I can see specifically where the problems are? If you send them, I can check to see if there is a relearn related to any of the components you replaced.
One last thing. Which engine does it have? Is it the 2.7L or the 3.3L
Let me know. Also, let me know the codes that you retrieved.
Sep 2, 2021 at 12:55 PM
