Crankshaft position sensor replaced same code came back
135,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
KEVENJRR
I recently replace the sensor because got the check engine code for it, after 4 days of installing the new sensor got the same code. Any needs to be done to the computer?
Jan 25, 2020 at 10:27 AM
  • 110,248 POSTS
Here are the directions for replacing the sensor. Take a look through them to see if you missed anything. However, chances are you didn't.
________________________
2011 Acura TSX Sedan L4-2.4L
CKP Sensor Replacement
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Crankshaft Position Sensor Service and Repair Removal and Replacement CKP Sensor Replacement
CKP SENSOR REPLACEMENT
1. Raise the vehicle on a lift.
NOTE: Make sure the vehicle is level, because engine oil will drip out when you remove the sensor.
2. Remove the CKP sensor cover (A).
pic 1
3. Disconnect the CKP sensor connector (B).
4. Remove the CKP sensor (C).
5. Install the parts in the reverse order of removal with a new O-ring (D).
_____________________________
Now, let me know the exact code you found. It may point me in a different direction for a cause. As far as the sensor, is the vehicle still running okay?
Jan 25, 2020 at 12:33 PM
SCGRANTURISMO
  • 4,897 POSTS
It could be a connection issue here is the engine wiring diagram and a guide to help check the connections.
Check out the diagrams (Below). Please let us know what you find.
Jan 25, 2020 at 1:17 PM
  • 110,248 POSTS
If you let me know the codes you found, it may help me direct you. Let me know this will help
Jan 26, 2020 at 8:38 AM
