Where is the crankshaft position sensor located?
200,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
KANDYCE GUERRA
Crankshaft position sensor location needed.
Dec 3, 2023 at 1:25 AM
  • 55,732 POSTS
The crankshaft angle sensor is on the left side of the engine behind the starter motor so it will need to be removed, start by disconnecting the battery. Here are the instructions on how to change the crankshaft sensor out. Check out the images (below). Let us know if you need anything else.
Dec 4, 2023 at 3:09 AM
