Where is the crankshaft position sensor located?
264,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
ALEXM1
Where is the crankshaft position sensor located on the vehicle listed above?
Sep 26, 2025 at 5:29 AM
CANNON1349
  • 861 POSTS
Hello, this will be towards the bottom on the transmission housing. It will be a straight forward repair to replace, I will include instructions and a picture below.
Turn the ignition switch Off and disconnect the battery negative (-) cable.
Remove the air cleaner assembly (Refer to "Intake And Exhaust System" in EM group).
Disconnect the crankshaft position sensor connector (A).
Remove the installation bolt (B), and then vertically remove the sensor from the transaxle housing.
Let us know how it goes,
William
Sep 26, 2025 at 11:32 AM
ALEXM1
Okay, thank you that helps a lot.
Sep 26, 2025 at 11:46 AM
CANNON1349
  • 861 POSTS
No problem, if you have any issues feel free to reply here. We are here to help!
William
Sep 26, 2025 at 11:47 AM
