Where is the Crankshaft position sensor located?
185,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
VICTORIANO O HERNANDEZ
Need location of crankshaft position sensor.
May 29, 2022 at 7:11 AM
AL514
  • 5,687 POSTS
Hello, technically it's on the side of the engine, but when facing the car, it's on the back under the exhaust manifold in the side of the engine block. You must do a crank relearn procedure as well after replacing the sensor. Or the vehicle will not run right.
May 29, 2022 at 9:33 AM
