Truck just turned off, will not start. Engine turns over fine, but nothing happens. Spark plugs are not firing. Bought a code reader, it said the crankshaft position sensor is bad. I replaced it, and tried to start and it did not start, but then the battery died. With the new sensor in place, should it start up like normal? Or does it take a bit to get everything back in order?
Jan 30, 2017 at 3:46 AM
