Crankshaft position sensor
247,000 MILES • 4.8L • V8 • RWD • AUTOMATIC
PATRICK DUBOIS
Truck just turned off, will not start. Engine turns over fine, but nothing happens. Spark plugs are not firing. Bought a code reader, it said the crankshaft position sensor is bad. I replaced it, and tried to start and it did not start, but then the battery died. With the new sensor in place, should it start up like normal? Or does it take a bit to get everything back in order?
Jan 30, 2017 at 3:46 AM
HMAC300
  • 48,601 POSTS
no it should start. try a security system reset that may be problem.
Jan 30, 2017 at 4:06 AM
PATRICK DUBOIS
It does not have a security system.
Jan 30, 2017 at 4:09 AM
SATURNTECH9
  • 30,868 POSTS
That should have a security system even if the key is not chipped does not mean there is not a security system.
Jan 30, 2017 at 5:07 AM
