Where is the Crankshaft Position Sensor located?
67,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
CDFULTZ
I have limited car maintenance knowledge and have not been able to find anything on the internet to locate the crankshaft position sensor. Been working through suggestions for mechanic friends and the internet suggestions. The car would run rough sporadically, stutter, and die sometimes when at low speed or backing up. Symptoms have improved but still has died when backing. I am looking for any help I can get finding the sensor on the engine or other suggestions.
Dec 21, 2024 at 5:16 AM
  • 110,248 POSTS
To access it, you have to remove the plastic cover under the engine compartment. It is located at the front of the engine.
I have attached directions for removal and a picture of its location below. Please take a look and let me know if you have questions.
Take care and let me know if this helps.
Dec 21, 2024 at 1:23 PM
CDFULTZ
Thank you!
Dec 22, 2024 at 11:37 PM
  • 110,248 POSTS
No problem whatsoever. I hope it helped. If you have other questions, let me know.
Take care, feel free to come back in the future, and I wish you and your family a Merry Christmas.
Dec 23, 2024 at 12:19 PM
