How do you relearn the crankshaft position sensor with a scan tool or without one for that matter if you cannot start the vehicle due to this problem? Everything I have seen says to crank the vehicle for the relearn process to start and then go through the rest of the steps. This initially started when I changed the starter out.
Nov 11, 2019 at 6:04 AM
