Crankshaft position sensor
240,000 MILES • 3.0L • V6 • 2WD • MANUAL
DANNYALLEN
Does the timing belt have to be removed to replace the CPS? My Chilton manual says it does, but I have seen diagrams showing otherwise. Thank you in advance for your answer.
Dec 13, 2017 at 3:33 PM
  • 31,937 POSTS
According to Mitchell 1 data base, the timing belt does require to be removed to access the crank position sensor.
Dec 13, 2017 at 8:07 PM
DANNYALLEN
Okay. And as long as the timing marks are lined up on both cams and the crankshaft that is TDC for cylinder number one correct?
Dec 14, 2017 at 3:36 AM
  • 31,937 POSTS
Yes, use the manual and you should not have a problem.
Dec 14, 2017 at 3:54 AM
DANNYALLEN
Okay. Thank you very much. Just never done anything involved with timing and no shop around me wants to touch it because of it being an interference engine. Mitsubishi wants almost $900.00 to do the job. Does not look difficult just looks meticulous. I will trust my Chilton and go with it, but thanks again and have a great day.
Dec 14, 2017 at 3:59 AM
  • 31,937 POSTS
just take your time, use a white pen to highlight all the timing marks so you can see them easily. it is not hard, but you must pay attention. take pictures and notes to help you remember small details any you will not go wrong. thank you for using 2carpros.
Dec 14, 2017 at 4:22 AM
