I need to know where the crankshaft position sensor is located to replace on my car listed above SEL model.
May 16, 2025 at 9:10 AM
✓Experienced Mechanic
Oh man, there is an access port and heat shield involved. The crankshaft sensor is on the left side of the engine near the bell housing. Here is a diagram to help. Check out the images (below). Let us know if you need anything else.
