Crankshaft position sensor. Can you tell me if I am supposed to have a 5 V reference signal on the black wire at the crankshaft position sensor? Also, what should my resistance be when the engine is running? And how should I test the voltage on the crankshaft position sensor when the engine is running? Any assistance would be greatly appreciated. Thank you so much for your time.
Sep 14, 2017 at 9:43 PM
