Crankshaft position sensor location
170,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
CDSLINGER
Where exactly is the crankshaft position sensor located on the vehicle listed above ES model?
Oct 19, 2018 at 2:47 AM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
The crankshaft sensor is located in the bell housing on your car, I have attached a diagram showing you the location. Hopefully this will help you out. Thanks for using 2CarPros
Oct 19, 2018 at 4:36 AM
