After replacing the Crankshaft position sensor, it is slightly misfiring occasionally and hesitates under load?
184,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
GWOLLINGER
Hi, I got a code for crankshaft position sensor, so I replaced it with an OEM from Chrysler dealership. I have a scanner with the relearn tool went through the process and now the vehicle has the same symptoms of the bad crank sensor but with no codes it slightly misfiring occasionally and hesitates under load. Also, if I look at live data on my scanner it says my crank is out of sync and my cams are in sync. I’m at a loss at this point. I'm not sure if I should tear this thing down and replace the timing chain but will be really upset if the chain is not bad. I don’t know if the computer just didn’t pick up the relearn process. Any suggestions would be great.
Thank you, Glenn
Feb 26, 2025 at 11:36 PM
  • 55,746 POSTS
Hi Glenn,
The crank and cams being out of sync will be the problem, I would make sure the oil is clean and full, if not change the oil and filter and clear the codes. Can you please give me the code numbers?
At 184k on the engine you don't need to worry about the timing chains not being bad, there probably are. I would change out the guides and camshaft actuators as well. Once I get the codes number I will know more.
Feb 28, 2025 at 10:58 AM
GWOLLINGER
After replacing the CPS sensor there are no codes, but the cams are in sync and the crank is out of sync. I’m wondering if maybe a chain tensioner is broken.
Feb 28, 2025 at 11:27 AM
  • 55,746 POSTS
That is very possible. did you get a chance to find the code numbers?
Mar 1, 2025 at 2:39 AM
GWOLLINGER
The only code I had was for the CPS sensor high circuit and I cleared it when I replaced it and did the relearn.
Mar 1, 2025 at 2:51 AM
  • 55,746 POSTS
High or low circuit codes are a clue the timing chains are worn out fyi.
Mar 1, 2025 at 3:11 AM
GWOLLINGER
That’s what I was afraid of, I’ll start to tear into it. thank you for your help.
Mar 1, 2025 at 3:43 AM
  • 55,746 POSTS
Yep yep, we are here if you need us for any help with the timing chain and camshaft actuators.
Mar 2, 2025 at 2:28 AM
