Will not start after replacing crankshaft position sensor
274,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
JDSAUERSR
  • 9 POSTS
I changed out the crankshaft position sensor on my car because it was losing power while driving and the code on an AutoZone scanner said crankshaft position sensor. After replaced with a new one, car had a rougher start, no loss of power but now, two days later, it won't start at all. What could be the issue?
Feb 21, 2019 at 8:13 AM
  • 110,246 POSTS
The sensor itself may be bad, came loose, damage to wiring, or a multitude of other things.
Now, what I suggest is this. First, confirm the sensor connector is tight, has no corrosion, and no damage to the pins.
Here are directions for removal and replacement. Make sure you did what the directions indicate. The attached pictures correlate with these directions.
CRANKSHAFT POSITION (CKP) SENSOR REPLACEMENT
REMOVAL PROCEDURE
picture 1
1. Disconnect the crankshaft position (CKP) sensor electrical connector (3).
2. Remove the starter.
picture 2
3. Remove the CKP sensor bolt.
4. Remove the CKP sensor.
INSTALLATION PROCEDURE
picture 2 again
1. Lubricate the CKP sensor O-ring seal with clean engine oil.
2. Install the CKP sensor.
NOTE: Refer to Fastener Notice in Service Precautions.
3. Install the CKP sensor bolt.
Tighten the sensor bolt to 10 N.m (89 lb in).
picture 3
4. Install the starter.
5. Connect the CKP sensor electrical connector (3).
_________________________________
If everything looks good, you need to check for an RPM signal or crankshaft position sensor signal. You will need a live data scanner to do that. See if the parts store will lend or rent one to you.
If you find there is no crank signal, I would replace the sensor which may have failed. If there is a signal, see if the engine starts for a couple seconds with starting fluid. If it does, then it is related to fuel.
Here are links that show how to check for spark to the plugs (can do this in place of scanning for a signal) and a link that shows how to check fuel pressure. If you find there is spark to the plugs, then the sensor is working.
Here are the manufacturer's specs for fuel pump pressure:
Fuel Pressure (Key ON, Engine OFF) .................... 345-414 kPa (50-60 psi)
Do this and let me know what you find or if you have other questions.
Feb 21, 2019 at 12:33 PM
BONGANI87
My car just swings, it doesn’t start. I’ve checked the spark plugs and there is no spark.
I’ve already changed the camshaft sensor. Any help please.
Dec 20, 2019 at 11:17 PM
  • 110,246 POSTS
Since the issue changed after replacing the sensor, that sounds like where the problem is. Have you checked the connector? Has anything come loose?
Take a look at the attached pic. Check the fuse I circled as well as check for ground for the coils.
Let me know what you find.
Dec 21, 2019 at 11:46 AM
