Crankshaft correlation faults
2,800 MILES • 4 CYL • AUTOMATIC
KANU
After changing a damage crankshaft, my car developed a fault called crankshaft correlation after diagnosing. And hard to start, mostly annoying stops along the way severally. please how do i get it fixed up?
May 13, 2017 at 10:28 AM
HMAC300
  • 48,601 POSTS
it's your cam/cranks sensor correlation assuming you got the cam timing correct from crank replacement then a mechanic h as to do it with his scanner.
May 14, 2017 at 5:57 AM
KANU
Thanks for your responses. Could it be that the cam/crank sensor is bad, assuming the timing chain is well fixed after the crank replacement? how do i know that the chain is not well fixed? What are the other possible effects of the crank correlation effects to the car? Can a mechanic uses his scan to fix up the crank correlation faults?
May 14, 2017 at 2:50 PM
HMAC300
  • 48,601 POSTS
the only way this will get fixed is to have a mechanic put it back in relation to crank sensor. it does not mean any sensor is bad it just means that it is like an older car out of time which it takes a pro scanner to fix this.
May 14, 2017 at 11:04 PM
KANU
Okay, thank you.
May 15, 2017 at 3:33 AM
  • 55,770 POSTS
Chances are the crankshaft is out of time with the camshaft.
https://www.2carpros.com/diagrams/toyota/camry/2004
Here is a guide to help you recheck it.
Cheers, Ken
May 17, 2017 at 9:01 AM
