Crankshaft causes transmission problems
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
GAIL ALLEN
I had my crankshaft sensor replaced and within a day the transmission needs to be replaced. I want to know if something happened to hurt the transmission when he replaced the crankshaft?
May 22, 2019 at 10:54 PM
STEVE W.
  • 15,413 POSTS
Hello and welcome to 2CarPros. If he replaced the crankshaft sensor then I doubt there is anything that would cause the transmission to fail as a result considering they don't touch the transmission to change the sensor. The sensor bolts into a hole in the engine block with one bolt.
What is the issue with the transmission?
May 22, 2019 at 11:46 PM
GAIL ALLEN
Thank you. I'm always afraid to get cheated, you put my mind at ease. I have to have my transmission rebuilt for $2,000.00. I was debating if it was worth it.
May 23, 2019 at 1:29 AM
STEVE W.
  • 15,413 POSTS
That's about normal for a rebuild. What isn't the transmission doing? Not shifting? Slipping?
May 23, 2019 at 5:04 AM
