New crankshaft bearings making noise
260,000 MILES • 0.8L • 3 CYL • 2WD • MANUAL
TEAMBSI
  • 39 POSTS
I have overhauled my engine and after about a month my crankshaft bearings are becoming noisy when I drive at a certain speed. I suspect it's the main bearings because it's not a knocking sound. Everything is new in the engine including the oil pump. Please help!!
Oct 3, 2020 at 9:18 PM
Good morning,
What was the clearance of the bearings when you installed them?
https://www.2carpros.com/articles/engine-noises
Can you upload a video of the noise so I can hear the noise?
Oct 3, 2020 at 9:40 PM
TEAMBSI
  • 39 POSTS
Hi, sorry for the late reply, had been working today. Nope, didn't check but what's the procedure on it? I can't seem to upload the recording due to file type but will create a link just now.
Oct 4, 2020 at 3:31 AM
TEAMBSI
  • 39 POSTS
Hi, here is the link to the noise. https://www.dropbox.com/s/qbq0qnre1eca3zk/Noise%20coming%20from%20crank.m4a?dl=0
Oct 4, 2020 at 4:13 AM
TEAMBSI
  • 39 POSTS
Hi, this is normal idling. https://www.dropbox.com/s/5t8et1a1gzl1rza/normal%20idling.m4a?dl=0
Oct 4, 2020 at 4:15 AM
I do not have a sign in for your drop box and cannot hear either file.
Oct 4, 2020 at 5:05 AM
STEVE W.
  • 15,410 POSTS
Listened to both files and it really sounds more like connecting rod rattle than main bearings. When you replaced the bearings the first time did you check the sizes of the original parts? Was there any damage to them? What was the reason for the rebuild?
Some manufacturers like to use every part they can so they will take a crankshaft that might be just a bit out of specification and grind it to the first undersize or even use different bearing sizes to make the clearances correct. Then you buy the standard parts from the parts store and discover that they are a loose fit. The only ways to check for those issues is to look at the original parts and the service manual to see exactly what their procedures are. For instance one make had bearings in multiple "off" sizes designated by color bands, you would measure the journal and then mix the bearings to get the correct clearance. The various bearings were only .001 thousands different so you might use a .002 and a .003 to make up for the true size of the journal.
Oct 4, 2020 at 9:00 AM
TEAMBSI
  • 39 POSTS
Wow! thanks for your answer, it makes a lot of sense.
Much appreciated!
Oct 5, 2020 at 7:04 AM
STEVE W.
  • 15,410 POSTS
You are welcome, sorry it isn't better news.
Oct 5, 2020 at 10:42 AM
TEAMBSI
  • 39 POSTS
Hi Steve, do perhaps know where can I get service manual for my car or can I maybe find the information in the Owner's manual?
Also, how exactly would you recommend I go about getting to the bottom of my issue?
Regards,
Bernard
Oct 6, 2020 at 5:42 AM
You are going to be doing a rebuild for this. This means breaking down the motor and replacing the mains, rod bearings, pistons, rings and a full gasket set.
I attached a site for you to go to. They have the engine manual and well worth the money.
https://www.tradebit.com/filedetail.php/281479066-2009-2015-chevrolet-spark-service-and-repair-manual?a=506906
Oct 6, 2020 at 5:55 AM
TEAMBSI
  • 39 POSTS
Really? But I have just done it about 2 weeks ago.
Oct 6, 2020 at 6:39 AM
Did you replace the mains and rod bearing? If you did, what was the clearances you set the bearings at?
Did you verify the oil pressure?
Oct 6, 2020 at 6:42 AM
STEVE W.
  • 15,410 POSTS
As Roy alluded to, once those parts start to fail there isn't anything you can really do other than open the engine up and see what the issue is. Say the bearings are bad, until you look at them and see what has happened with regards to the metals they are made out of has done. It could be that you will only need to replace the rod and main or maybe just the rod bearings, but if a bearing has started to flake apart or worse more than one, those pieces need to be flushed out and removed, then measure the parts in question and see what can be done.
The other option would be to find a used or remanufactured engine and swap that in and go through the one you have at a different time.
Oct 6, 2020 at 11:10 AM
TEAMBSI
  • 39 POSTS
Thank you so much for dealing with all my questions, I find your advice really helpful.
Keep up the good work!
Regards,
Bernard
Oct 6, 2020 at 11:08 PM
You are welcome.
Oct 6, 2020 at 11:11 PM
