Crankshaft and camshaft correlation code?
234,356 MILES • 3.7L • V6 • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Hello, there is a code on the engine indicating Crankshaft and camshaft correlation code. Something the RPMs will fluctuate while the engine is running.
Could I get the location of the crankshaft position sensor with his wire diagram and the camshaft position sensor wire diagram?
Thank you
May 5, 2025 at 10:31 AM
  • 55,711 POSTS
Can I get the code number? Chances are the sensors are okay, and the engine is having a mechanical problem, IE: bad timing chain, guides, camshaft actuators, or you could have dirty or low engine oil.
May 6, 2025 at 4:42 AM
BLESSING EWOBOR
  • 753 POSTS
It is intermittent code, I will communicate it once it shows again.
May 7, 2025 at 12:13 PM
  • 55,711 POSTS
Sounds good.
May 8, 2025 at 3:46 AM
