Where is the Crankshaft sensor located?
130,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
MINDY WILLIAMS
Please tell me where the crankshaft sensor is located on this vehicle. I'm getting conflicting information.
The car listed above is a Police 3.6L DI FFV DOHC six cylinder.
Aug 5, 2021 at 2:21 AM
SQM
  • 6,383 POSTS
If you are facing the engine; The crank position sensor is located on back of the engine lower right hand side (see diagram below).
You might find these articles helpful:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
I have also attached the replacement procedure.
Please note that some of these crank sensor requires reprogramming using a specialty scan tool.
Aug 6, 2021 at 8:14 AM
