crankshaft
1,000 MILES • V8 • 2WD • AUTOMATIC
JLOBAINA
  • 18 POSTS
I need to know where the crankshaft is located need to check it
Apr 5, 2016 at 9:13 AM
CARADIODOC
  • 34,405 POSTS
What exactly are you hoping to check? What is the problem or symptom? The crankshaft is inside the engine. All you can see of it is the vibration damper / pulley on the front end of it. That is the lowest one on the front of the engine.
Apr 5, 2016 at 12:05 PM
CJ MEDEVAC
  • 11,000 POSTS
TAKE OFF THE OIL PAN AND YOU WILL BE LOOKING UP TO SEE THE COUNTER WEIGHTS (THE MAIN BEARING CAPS AND CONNECTING RODS WILL OBSCURE A LOT OF IT. ONE END WILL PROTRUDE OUT OF THE FRONT AND HAVE A HARMONIC BALANCER/ PULLEY ON IT, THE REAR END OF WILL BE IN THE BELL HOUSING W/ A FLEXPLATE/ FLYWHEEL ATTACHED TO IT
I FOUND A PIC OF ONE ON THE NET (NOT YOURS), IT IS INSTALLED IN THE ENGINE BLOCK
THE MEDIC
Apr 5, 2016 at 12:07 PM
