crankshaft position sensor location and replacement?
220 MILES
JOHN JAY GO THOMAS
Where is the crankshaft position sensor located and how to change it?
Dec 20, 2019 at 2:44 PM
Good morning,
You did not list the engine size so I attached pictures of both engines of the location. Why are you replacing the sensor? Do you have a code or does the engine not run? Check out the diagrams (Below). Please let us know what happens.
Dec 20, 2019 at 10:33 PM
BOYNTONSTGARAGE
where is the problem here im find a lot of different opinions some say the ifs sensor or crank sensor or cam sensor car runs fine light just came on?
Feb 5, 2021 at 2:16 AM (Merged)
Here are some guides on how to replace the CKP sensor plus some more info on what happens when a CKP sensor fails.
Plus here is some more info on how to replace, location, and general info on the crankshaft position sensor.
Let us know if you need more info. Thanks
EMILY.BOURQUE
i need to know the location of the crankshaft position sensor, and the location of where each end plugs in.
Feb 5, 2021 at 2:17 AM (Merged)
  • 75,988 POSTS
See below, the other end is at the computer
https://images.2carpros.com/forum/automotive_pictures/12900_cps_8.jpg
627NMM
Engine cranks but no ignition to plugs code is PO335 crankshaft position sensor circuit malfunction. will this code cause no ignition. Where is the sensor at.
  • 75,988 POSTS
The CPS is on front of engine
https://images.2carpros.com/forum/automotive_pictures/12900_cps_44.jpg
BIGFOOT15
  • 25 POSTS
Good answer rasmataz? Should be able to just open the hood & look in there with a flashlight,riiiiight?Its right there in plain sight on the front of the engine.NOT.
CRIGDON
I was driving my car asnd everything was running good pulled up to a stop sign and i died. I got it towed home pulled off the timingbelt cover and there are teeth missing off the belt. I am assuming that the teeth have have messed up the crankshaft sensor. I would like to know where to locate this sensor ajnd how to check/change it out if needed. and also is it very hard to replace timing belt. I dont think it jumped time or anything as the dohc marks are pointing up and look to bein the right position but i am not 100% sure. Please i can not afford to donate any money as i have a 3 yr old son and a 2month old baby girl. PLEASE HELP
TAZZMINI
  • 5 POSTS
i have the same problem i did replace timing belt but still no start. to change the belt you will have to remove all belts and pullies and the motor mount just to take the old one of.
2CP-ARCHIVES
  • 4,540 POSTS
Where is the crankshaft position sensor located in 2.7 v6 engine
Feb 5, 2021 at 2:27 AM (Merged)
KHLOW2008
  • 41,812 POSTS
The crankshaft angle sensor is located on the bell housing on the drivers side here is a guide to help you see what you are in for when doing the job.
Check out the diagrams (below).
Cheers
JRJ703
I love this site.
SANRON1
I would like to know location and how to route wire?
  • 75,988 POSTS
Here is a guide to help you see what you are in for when changing the sensor out plus the location of the sensor for both the four and six cylinder engines below. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
