crankshaft reprogramming?
146,765 MILES • AUTOMATIC
LEILANI CHANCEY
How do I reprogram my car after changing the crankshaft.
Mar 28, 2021 at 5:18 AM
STEVE W.
  • 15,413 POSTS
If the crankshaft is a factory part there is no programming needed as there are no adjustable parts. If you meant a crankshaft position sensor then you may need to erase the learned values for the old one, for that you need a scan tool that can erase them.
What was the original issue?
Mar 28, 2021 at 6:51 AM
