crankshaft
2005 FORD FOCUS
129,000 MILES
RONNIE THOMPSON
My car has been starting cold, but when I stop and the engine is warm it struggles to start. I have looked at the crank sensor, the plug and wires were covered in oil from a leak somewhere. Could that be the problem? And will it be okay if I just clean the oil off.
Mar 13, 2016 at 4:19 AM
HMAC300
  • 48,601 POSTS
clean off the wires and scan for codes. Check the fuel pressure with a gauge most auto parts stores rent it.
Oct 8, 2018 at 8:08 AM
RONNIE THOMPSON
Thanks for the reply. Now I am stuck with a tripped immobilizer nothing at all, no cranking the key is not recognized. Will my spare key work (not fob)?
HMAC300
  • 48,601 POSTS
the spare may work if not try resetting it, if no manual look online for your car to reset
