Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
S-10
Engine
Symptoms
Not Running
Cranks will not start
1996 CHEVROLET S-10
95,000 MILES • V6 • 2WD • AUTOMATIC
JAMIE SARTAIN
MEMBER
Turns over will not start unless put 200 amp start battery charger on it or give shot of ether starter fluid or pour gas in it.
Mar 31, 2018 at 2:55 AM
Experienced Mechanic
Good afternoon.
First thing is to charge the battery until you have 12.6 volts at the battery.
Then check the fuel pressure. If it started with ether, then it sounds like a fuel delivery issue.
Mar 31, 2018 at 4:52 AM
JAMIE SARTAIN
MEMBER
Just out over size battery it has get up to 16 volts to start. if turn on A/C going down road it shuts off. what could be wrong with fuel delivery?
Mar 31, 2018 at 9:20 AM
Okay, so the engine runs now?
Is 16 volts with it running because if it is not running and you measure 16 volts, the battery is not good.
I am wondering if the A/C compressor is locking up.
Mar 31, 2018 at 9:26 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
