Cranks will not start?
150,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
IKEBMAN
I changed the spark plugs. I checked the spark plugs out of the cylinders and no spark cleaned build up out the distributor and gave fresh clean surfaces. It was running fine when I parked it a week ago. The rear motor/transmission mount came unbolted, and it wouldn't go in any gears other than first until I got it home and hoisted the engine a transmission up and managed to (over a period of days by myself not knowing what I was doing) get it remounted and have all gears it seems. But now that it's all back together it won't even fire. Any advice is greatly appreciated it was my only reliable vehicle.
Apr 23, 2023 at 2:06 PM
  • 110,248 POSTS
The most common cause of a crank no start condition is either no fuel to the engine or loss of ignition spark.
Here is what I need you to do. First, see if the engine starts if you use starting fluid. If it does or tries to start and then stalls, we know it is a fuel-related issue. If there is no change using starting fluid, then we need to check for spark at the spark plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
If you could, record it cranking and upload it for me to hear.
Do this and let me know the results.
joe
Apr 23, 2023 at 2:55 PM
IKEBMAN
So I used gasoline instead of starting fluid but it still wouldn't start so I checked for spark but not as was described in the video so I'm going to double check, but once I gotten done checking the way I did I opened up the distributor cap and there was a decent amount of corrosion and lines eaten out of two of the posts inside the distributor so I cleaned it up with a fine file and got the same result is it possible that that corrosion and the file took too much off of the distributor posts and they aren't close enough to cause spark? I appreciate you taking the time to assist me with this very much. I'm at a loss for ideas I can afford or am capable of.
Apr 25, 2023 at 2:26 AM
  • 110,248 POSTS
Try this: Let's see if there are diagnostic trouble codes present. You don't need a scanner on this vehicle. Follow the directions in this link and let me know what you find:
https://www.2carpros.com/articles/nissan-obd1-diagnostic-trouble-codes-and-retrieval-procedure-1984-to-1994
Apr 25, 2023 at 1:18 PM
IKEBMAN
Thank you so much, Joe. I will try this right away; I thought I had to have like a factory stereo or a code reader in order to even try to retrieve the codes.
Apr 30, 2023 at 3:55 AM
  • 110,248 POSTS
You are very welcome. Let me know what you find. I'm interested in knowing.
Apr 30, 2023 at 11:21 AM
