Crank no start issue, cylinders are not getting spark?
216,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
DUNCAN HUTTON
It cranks but won't start, I have no spark to any of the cylinders.
Nov 9, 2022 at 2:20 AM
  • 110,248 POSTS
By chance, do you have a live data scan tool? If you do, check to see if there is an RPM signal when the engine is cranking. If you don't have a scanner, see if the tachometer moved a little when cranking.
Take a look through this link and let me know if it seems to mirror what you experience.
Also, the ignition coil may have failed. I believe the coil is integral to the distributor.
Nov 9, 2022 at 9:18 AM
