Engine cranks will not start?
70,000 MILES • 2.8L • V6 • 2WD • AUTOMATIC
MADATMYTRUCK7
  • 5 POSTS
It ran fine then it sat for a over a year. Replaced the fuel and fuel filter, rotor, cap, plugs, plug wires.
Tried to turn over when it's primed then quits, just cranks.
Aug 1, 2023 at 11:56 AM
  • 110,248 POSTS
If it tries to start when you prime it, then it is a fuel-related issue. Have you checked the fuel pump pressure to make sure it is within the manufacturer's specifications? If not, that is where I would start.
Here is a link that explains how it's done:
Also, check to see if there are diagnostic trouble codes stored. This vehicle has an OBD1 system and doesn't require a scan tool to retrieve codes. All you will need is a short jumper wire or even a paper clip.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Try these two things and let me know the results. Also, I attached the manufacturer's fuel pressure specifications below for you. You will need a fuel pressure gauge to do this, but if you don't have one, most parts stores will lend one to you.
See pic below.
Aug 1, 2023 at 3:55 PM
MADATMYTRUCK7
  • 5 POSTS
Thank you Joe, I'll give it a go and give you a full report.
Aug 1, 2023 at 4:46 PM
MADATMYTRUCK7
  • 5 POSTS
I did the 9-bolt battery truck on the jets. One let a couple drops out the other nothing. Some pictures.
Aug 2, 2023 at 7:46 AM
  • 110,248 POSTS
The wiring looks like someone was checking things in the past. Is the injector connector on the left burnt? I see black areas.
Also, if you were not getting fuel when you ran power, it sounds like either an injector issue or the wiring. I'm not sure where you tested from.
Aug 2, 2023 at 12:45 PM
MADATMYTRUCK7
  • 5 POSTS
I took a transistor radio battery and connected it to the contacts on the injector contacts. The left dribbled a drop then quit and the right (burnt on top for some reason) did nothing. I have not tried the first two tests yet. Will try that today. The bigger problem is I have MS and my hands can be an issue at times.
Aug 3, 2023 at 2:26 AM
  • 110,248 POSTS
I'm sorry to hear about your hand issues and the cause. There is absolutely no rush, so take as much time as you need. I'm here when you are ready.
Please feel free to let me know if you have questions or if I can help in any way.
Take good care of yourself,
Aug 3, 2023 at 1:34 PM
MADATMYTRUCK7
  • 5 POSTS
Thank you, Joe, it was the fuel pump unfortunately.
I got a good deal to get it replaced locally.
Thank you for your help.
Best- J.
Aug 11, 2023 at 2:23 AM
  • 110,248 POSTS
Thanks for the update. I appreciate it. Well, I'm glad you found the problem. I wish it was something easier to deal with.
Regardless, please feel free to come back anytime in the future if you have questions or if I can help in any way. You are always welcome here.
Aug 11, 2023 at 3:21 PM
