Cranks, will not start
119,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JKGRIFFITHS2007
Recently I cleaned my throttle body with throttle body cleaner. After a few cranks it finally started. I drove it about 20 miles came home. Tried to start it the next day would not start. Put the pedal to the floor, again no start. Why?
Normally I remove throttle body to clean, but was lazy this time.
Jan 1, 2020 at 12:57 AM
Did you remove the MAP and throttle position sensor? If not then the chemical in the cleaner can damage these sensors. if they are damaged then it can cause a no start.
I would suggest starting with checking for codes and seeing what is there. This will keep us from guessing as to which sensor it is if I am correct.
Mar 11, 2021 at 10:34 AM
JKGRIFFITHS2007
No codes. Plugs are brand new, but when I pulled them they looked 20 years old. I am guessing all that carbon from cleaning the TB burned them black. Cleaned my plugs now it's running fine.
Makes sense. Thanks for the update. Glad you got it going.
