Alright, so I got this car from a guy not running. He got it without the gas tank. Meaning no fuel pump or sending unit or tank. He found one out of an IROC. (This is the base model 2.8l v6 multi-port fuel Injection) He also bought a brand new sending unit and fuel pump for it. So soon as I get it, I install the sending unit and fuel pump into gas tank and install all of that in the car. Put four gallons of gas in there to get the needle to move from empty. Still will not start. I replace the fuel pump relay and the connector because I noticed it was broken and burnt out. Still did not fix the problem. I also replaced the 20 amp fuse for the fuel pump relay. Also dropped a brand new battery in there as well. Still does the same thing. I know the guy swapped the distributor out. He said he set the firing order just right and timed it but mistakes happen. Does anyone have any suggestions or can help me?
Jan 13, 2018 at 6:05 AM
