Codes po340 and po365, engine cranks over will not start
100,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
JOSEPH601
  • 13 POSTS
I've replaced crankshaft sensor, checked VVT actuators on cams getting fuel getting spark. I'm getting a po340 and po365 which are circuit interruption with cam shaft sensors. They both checked out good. I'm lost on it.
Jun 10, 2022 at 2:04 AM
  • 110,251 POSTS
If the sensors are good, you must be dealing with a wiring issue. Are these the only codes that are present? When the vehicle is running, how does it act?
As far as the wiring, I attached pinpoint, diagnostic testing below. Take a look through them and let me know if you are comfortable performing them. Also, here is a link you may find helpful when testing wiring:
Jun 10, 2022 at 2:29 PM
JOSEPH601
  • 13 POSTS
These are the only codes I'm getting now, and the car won't crank and run at all, it just turns over but won't start and run. I was told it may be that it needs an oil change because that's what controls the timing by oil pressure it advances and retards timing with the cam actuator solenoids. I let the oil get over the oil life percentage ignored it twice they said the oil broke down and has sludge and dirty not giving the right pressure as new oil and the car must be changed every three thousand miles. I'm lost.
Jun 11, 2022 at 2:25 AM
JOSEPH601
  • 13 POSTS
P0013, P2091, and P0641.
Jun 11, 2022 at 2:28 AM
JOSEPH601
  • 13 POSTS
I really need this car back running. Also, the wireless key start with the key fob remote doesn't work anymore either, but was working before it did this no start issue if that matters.
Jun 11, 2022 at 2:31 AM
  • 110,251 POSTS
The oil should be serviced, but unless it has become tar in the engine, it wouldn't prevent it from starting.
The codes you provided indicate there is a short to power at the exhaust cam actuator. Disconnect it and check for a 5v reference to it. Let me know what you find.
Jun 11, 2022 at 12:42 PM
JOSEPH601
  • 13 POSTS
Check the pigtail wire that goes to actuator is that correct. Which color wire should I check and does ignition need to be on are off?
Jun 12, 2022 at 7:21 AM
  • 110,251 POSTS
At the actuator, there should be a gray wire with a blue tracer and a black wire with a violet tracer. The gray/blue should have the 5v reference. The black/violet is a low reference wire which is basically a ground provided via the PCM.
Take a look below at the pic.
See pic below.
Jun 12, 2022 at 1:10 PM
JOSEPH601
  • 13 POSTS
This is voltage to the hot wire on both camshaft actuator solenoids intake side and exhaust side which is 11.2.
Jun 13, 2022 at 2:37 PM
JOSEPH601
  • 13 POSTS
This is voltage to one of the 3 wire plugs on both camshaft sensors intake side and exhaust side which is 4.9 volts.
Jun 13, 2022 at 2:39 PM
JOSEPH601
  • 13 POSTS
Can this be a computer problem in the car are how likely is that to be?
Jun 13, 2022 at 2:44 PM
  • 110,251 POSTS
You are basically getting battery voltage to the sensors. That's the problem. You asked the probability of it being a computer. I don't like saying it, but the chances are higher than I would like. However, it could simply be a short.
I attached diagnostics to further your testing below. They are broken into steps. You have already completed some of the preliminary tests. Read through them and see what you find. After I read through them, I feel you either have a short to B+ on the 5v reference or the ECM is bad.
If you look down to step 4 of the diagnostics, you have already verified there is too much voltage, so the directions are indicating to disconnect the ECM and start checking at the ECM K20 module. In section 4, go down to where it indicates more than 5.2V and continue from there.
Remember, The ECM can supply 5v or 12v to various sensors. This is done through a pull-up resistor to regulate the power supplies within the ECM. If you get B+ voltage to the 5v signal wire right at the PCM, the resistor has failed.
Take a look through the diagnostics below and let me know if you have questions.
Jun 14, 2022 at 12:35 PM
JOSEPH601
  • 13 POSTS
I'm getting battery voltage at solenoid actuators intake exhaust side and no volts at ECM wiring of either of the four wires running out ECM plug to solenoids.
Jun 15, 2022 at 5:42 AM
JOSEPH601
  • 13 POSTS
I've test the wires hooked up to ECM with key on and off also checked wires unhooked from ECM with key on and off no voltage at ECM, but has the battery's voltage at solenoid actuators even now that my battery is down to like 8.3 volts since car not running and me not putting charger on it. It reads the 8.3 volts at solenoids when it was reading 11 something volts at solenoids before when battery had the more volts. this this car has me so messed up.
Jun 15, 2022 at 5:49 AM
  • 110,251 POSTS
Are you getting power from the ECM? You indicated you don't. But, when you connect the ECM, do you have B+ voltage to the solenoids? I ask because that doesn't make sense to me unless there is a short to power in the ECM wiring harness. Also, if you are getting no voltage right at the ECM, chances are it has failed, and needs replaced.
Let me know. Sorry, I'm just trying to clarify what exactly is happening.
Jun 15, 2022 at 2:55 PM
JOSEPH601
  • 13 POSTS
At the black connector on ECM with key on I'm not getting any voltage at the wires but at the connectors of the solenoid actuators I'm getting battery voltage whatever's in my battery. There's a blue black and gray connected on the ECM the wires I traced back from the actuator's go to the black one.
Jun 16, 2022 at 2:48 AM
  • 110,251 POSTS
If you are getting nothing at the ECM, I suspect it's bad. As far as the power at the actuator, B+, I suspect you are getting power from the ECM through the wrong wire, or when you connect the ECM, there is a pin that is shorting power to it. Otherwise, nothing would make sense. If you traced the wires back to the ECM and there was nothing damaged or shorting, that is what I suspect is happening. Something in the ECM has shorted. Even if there was a pin in the connector that was bad, that wouldn't explain why you don't have a 5v reference at the ECM.
Jun 16, 2022 at 2:48 PM
JOSEPH601
  • 13 POSTS
Okay, I went back over everything I'm getting battery voltage out of ECM on both 5v reference wires I assume that assures me going to need new ECM and it flashed to my VIN.
Jun 23, 2022 at 10:21 AM
  • 110,251 POSTS
It sounds like something shorted internally. I suspect you are correct. Here is what I suggest.
There are several places online that sell remanufactured ECMs. About a year ago, I had to replace my own. Here is the good part: it wasn't too expensive, and they prepared it to simply be a plug-and-play install.
I questioned if it was going to work, but all I did was remove and replace it, the truck started right up, and I haven't touched it since.
Once I received the ECM, I had 7 days to return my old one. They gave me 7 days to confirm the one I received was good.
It's a thought. I think I paid around $150.00 for it
Let me know if I can help. Also, let me know if this takes care of the issue.
Jun 23, 2022 at 2:05 PM
JOSEPH601
  • 13 POSTS
Okay, I will let you know as soon as I get one. Thank you for your help, God bless.
Jun 23, 2022 at 3:00 PM
  • 110,251 POSTS
You are very welcome and God bless. I feel everyone in the world anymore could use a good blessing.
Take care of yourself.
Jun 23, 2022 at 3:26 PM
