My engine not starting up?
COSMONETO
  • 1996 FORD F-150
  • 5.9L
  • 6 CYL
  • 200,000 MILES
Installed new MAF tested good, new fuel pumps, fuel regulator. Cranks over will not start. If I disconnect the MAF it runs just fine.
Thursday, October 5th, 2017 AT 3:32 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,785 POSTS
Will everything connected can you run the codes to see whats comes up here is a guide t help us get started.
This sounds like a fuel pump or the crankshaft angle sensor has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Monday, May 31st, 2021 AT 12:43 PM
COSMONETO
When this problem started it was not showing any codes I tried 4 different code readers finally it showed p0505 idle air controller replaced it runs like a charm
KEN L
  • 47,785 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
