Cranks over but will not start or fire
49,000 MILES • 3.8L • V6 • 4WD • AUTOMATIC
UNHAPPY HEMI-OWNER
Code 0137 is set and the plan was to replace the O2 sensors soon. It was running fine and then intermittently the brake and stability control lights came on. Shortly thereafter, it wouldn't start.
Mar 1, 2020 at 11:13 AM
  • 110,248 POSTS
The O2 sensor won't prevent it from starting. As far as the brake light, make sure the brake fluid isn't low. For now, lets get it running and then focus on the other two things.
First, I need to know if the engine is getting spark and fuel. Here are three links. First discusses the most common causes of a crank no start. The second two show how to test for fuel pressure and for ignition spark.
________________________________
Here are the directions for testing fuel pressure specific to your vehicle. Pressure specs are included in the directions. The attached pictures correlate with the directions. These directions require specific tooling.
2008 Mitsubishi Truck Endeavor AWD V6-3.8L (6G75)
Component Tests and General Diagnostics
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Testing and Inspection Component Tests and General Diagnostics
COMPONENT TESTS AND GENERAL DIAGNOSTICS
The content of this article and images reflects the changes identified in TSB - 10-13-008.
FUEL PRESSURE TEST
Required Special Tools:
- MB991958: Scan tool (M.U.T.-III Sub Assembly)
- MB991824: V.C.I.
- MB991827: USB Cable
- MB991910: Main Harness A
- MB991981: Fuel Pressure Gauge Set
- MB992001: Hose Adaptor
- MB992049: Quick Connector
- MB992076: Injector Test Set
1. Release residual pressure from the fuel line to prevent fuel spray.
WARNING: To prevent a fire, cover the hose connection with shop towels to prevent splashing of fuel that could be caused by some residual pressure in the fuel pipe line.
pic 1
2. Disconnect the fuel high-pressure hose at the fuel rail side.
3. Assemble the special tool MD998707 of special tool as shown in figure.
NOTE: The special tool MB992076 (injector test set) is compatible with the special tool MB998706 (injector test set).
In case of vehicle using (square) quick connector
W/ Square Quick Connector
pic 2
(1) Remove the injector installation adapter from the hose. Remove another hose together with the adapter and remove the adapter from the remaining hose.
(2) Install the special tool MB992049 (quick connector) and the special tool MB992001 (hose adapter) to the hose without the adapter.
(3) Remove the nipple of the bolt of the special tool MD998709 (hose adapter).
(4) Install the special tool prepared in the procedure (3) to the nipple that was removed together with hose in the procedure (1).
In case of vehicle using (round) quick connector
W/ Round Quick Connector
pic 3
(2) Install the special tool MB991990 (quick connector) and the special tool MB992001 (hose adapter) to the hose without the adapter.
4. Install the special tool assembled in step 3 between the fuel rail and the fuel high-pressure hose.
[When using the fuel pressure gauge]
pic 4
1. Via a suitable O-ring or gasket, install the fuel pressure gauge to the special tool that has already assembled as described.
2. Install the assembled fuel pressure measurement tools between the fuel rail and fuel high-pressure hose.
pic 5
[When using special tool MB991981 (fuel pressure gauge set)]
1. Via a gasket, install the special tool MB991981 (fuel pressure gauge set) into the special tool that has already assembled as described.
pic 6
CAUTION: To prevent damage to scan tool MB991958, always turn the ignition switch to the "LOCK" (OFF) position before connecting or disconnecting scan tool MB991958.
7. Connect scan tool MB991958 to the data link connector.
8. Use Actuator test 9 to drive the fuel pump. Check that there is no fuel leaking from any section when the fuel pump is operating.
9. Stop the fuel pump.
10. Start the engine and run at idle.
11. Measure fuel pressure while the engine is running at idle.
Standard value: Approximately 324 kPa (47 psi) at curb idle
12. Check to see that fuel pressure at idle does not drop even after the engine has been revved several times.
13. If any of fuel pressure measured in steps 11 to 12 is out of specification, troubleshoot and repair according to the table below.
pic 7
14. Stop the engine and observe fuel pressure gauge reading. It is normal if the reading does not drop within two minutes. If it does, observe the rate of drop and troubleshoot and repair according to the table below. Start, then stop the engine.
1. Squeeze the fuel supply line closed to confirm leak-down occurs from defective fuel pump check valve.
2. If pressure continues to drop with both fuel lines squeezed closed, injector(s) are leaking.
pic 8
15. Release residual pressure from the fuel pipe line.
WARNING: Cover the hose connection with shop towels to prevent splash of fuel that could be caused by some residual pressure in the fuel pipe line.
16. Remove the fuel pressure gauge and special tool from the fuel rail.
17. Fit the fuel high-pressure hose to the fuel rail.
18. Check for fuel leaks.
1. Use scan tool MB991958 to operate the fuel pump.
2. Check the fuel line for leaks and repair as needed.
19. Disconnect scan tool MB991958.
If you are unable to perform these tests, see if the engine starts for a couple seconds using starting fluid. If it does and then stalls, we know it is a fuel related issue.
Let me know what you find.
Mar 1, 2020 at 11:50 AM
UNHAPPY HEMI-OWNER
Hi Joe,
Thanks for your detailed reply but right after I posted my question, I found the answer on your website (awesome job, kudos to you all!).
Even though I've done quite a bit of work on newer vehicles, my "old school" mentality says if the battery has enough power to crank the car over, it has enough power to fire the car. While this was the case in older vehicles, it is no longer true. I used another car to jump the Mitsubishi and it fired up so all I need to do is replace the battery!
The lesson that I have learned and am hoping to remember is that when there is a no start condition, check the battery voltage first and verify that it is over 12.5V. Also observe the voltage while cranking the car to make sure it doesn't have significant voltage drop. Well, I will test that as soon as I replace the battery.
Thanks again for your excellent website!!
Steve
Mar 2, 2020 at 9:32 PM
UNHAPPY HEMI-OWNER
One other question that I do have if you have any information is regarding the OBD2 reading on the 2008 Mitsubishi Endeavor.
I have 2 scanners, a VeePeak Bluetooth that uses a Phone App and a handheld scanner which just reads codes. I've tried 2 apps with the VeePeak and neither can establish communication with the Endeavor while the handheld unit has no problem communicating with it. They both handle CAN protocol but looking at the Apps, it looks like there are numerous CAN protocols.
Do you know which protocol the Endeavor uses?
Thanks again!
Mar 2, 2020 at 9:38 PM
  • 110,248 POSTS
On an 08, that shouldn't be an issue. What exactly is it indicating? I was able to find the interface and some requirements. See if any of this helps.
How to diagnose the can bus lines
- MB991958: Scan Tool (M.U.T.-III Sub Assembly)
- MB991824: Vehicle Communication Interface (V.C.I.)
- MB991827: M.U.T.-III USB Cable
- MB991910: M.U.T.-III Main Harness A (Vehicles with CAN communication system)
Mar 3, 2020 at 11:21 AM
