Hello –
We need to make sure you and I are on the same page so I am gonna need a little more info if that’s okay.
First is your Camry a CE, LE, Solara SE or XLE?
Next, a basic tune up….did that include new plugs, plug wires, air filter?
Battery voltage good – did you have a draw test done on it?
Please do me a favor, please go to Auto Zone or O’Reilly’s and for FREE they can pull the codes to the car. I know you did this but have them check once more. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. Very big, while there for FREE also they can bring their tester out and check your battery, alternator and starter.
We need to figure out if it is electrical or fuel related. Pull a plug wire off of the spark plug and insert something into the end of it and have someone try to start the car and have the metal object really close to a piece of metal on the engine and see if you are getting a good strong popping blue spark. Don’t have your hands on any part of the metal!!! If there is no spark, then it is electrical. If you are getting good spark then you need to get a fuel pressure check on the fuel pump to ensure it is putting out okay. You have already said you checked the fuel pressure – do you remember what it was so when you give me the correct model vehicle I can compare it?
Please do the above and let’s take it from there.
Feb 22, 2021 at 1:19 AM
(Merged)
