Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
LS
Engine
Symptoms
Not Running
cranks no start?
2005 LINCOLN LS
109,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
UTIGARD
MEMBER
1 POST
39 PSI fuel pressure. 12volts, no start very intermittent.
Oct 27, 2022 at 3:32 PM
Experienced Mechanic
So, the engine is cranking over, correct? Will it run on starting fluid? Also do you have spark?
This video will show you how to check for spark:
https://youtu.be/baq_aEWNQ0Y
Please go over this guide as well:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over these guides and report back.
Oct 29, 2022 at 4:32 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
