Cranks no start Exactly that, cranks but doesn't start?
160,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
GTCIRCUS
Exactly that, cranks but doesn't start.
Jan 17, 2020 at 5:12 AM
Good afternoon,
Can you hear the fuel pump run when you turn on the key?
You need spark, fuel pressure and compression for it to run.
I would check the fuel pressure and check for spark at a spark plug.
I attached some charts for you to follow.
Let me know the results. See if the tachometer moves up a little while cranking. That will tell me if the crank sensor is working.
May 31, 2021 at 5:38 AM
GTCIRCUS
Got it, fuel module it turns out was bad, all fixed!
  • 55,766 POSTS
ASEMASTER6371 is one of our best! Good to hear, please use 2CarPros anytime we are here to help.
