Cranks no start
183,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
77JOHN77
Truck listed above is a 1500 5.3L vortec stalled on me last Saturday. I have replaced the fuel pump, fuel filter, plugs, plug wires, and coils and the truck doesn't want to start. I have fuel at the shrader valve an i have spark so what else could be keeping it from running?
Mar 23, 2020 at 2:27 AM
Good afternoon,
I would start by checking the compression if you have fuel and spark to be sure the timing chain has not slipped.
Can you test the actual fuel pressure? You need to be sure the proper pressure is at the fuel rail.
Mar 23, 2020 at 2:32 AM
77JOHN77
It has compression and i pushed the shrader valve in with a small screw driver and fuel sprayed out. as far as the radiator but i do not have a tester to test just how much pressure i actually have.
Mar 23, 2020 at 2:51 AM
You can rent a tester at a part store that will hook to the port and give you the pressure.
What was the compression?
When you crank the engine does the tachometer move up a little?
Is the check engine light on?
Mar 23, 2020 at 2:56 AM
77JOHN77
If i remember correctly it was like 123 to 126 and yes the tachometer moves up a little and the check engine light is on.
Mar 23, 2020 at 3:00 AM
Compression is low.
https://www.2carpros.com/articles/the-reasons-for-low-compression
The crank sensor is working.
Any idea on the fuel pressure?
Can you give me the code?
If you spray some starter fluid in the air filter, does it start and stall?
Mar 23, 2020 at 7:23 AM
