Cranks, has spark, no fuel pulses at fuel injectors
2002 GMC SIERRA
190,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
DEANNA MCCOY
Truck ran when parked 5 years ago as transmission went bad. Just replaced transmission and now truck won't start. Replaced fuel regulator, new battery, engine cranks and has spark just not getting fuel to injectors.
Nov 21, 2020 at 2:50 PM
DANNY L
  • CAR REPAIR CONTRIBUTOR
  • 5,648 POSTS
Hello, I'm Danny.
You say you replaced the fuel regulator but you might have a failed fuel pump due to sitting for so long. I would suggest to first perform a fuel pressure test. If you don't have access to a fuel pressure tester most auto parts stores have a tool loaner program and can rent you one. Here is a tutorial showing what is involved:
After performing this test get back to us with the results and we'll go from there. The proper fuel pressure for your truck should be 55- 62 psi with key on-engine off. Hope this helps and thanks for using 2CarPros.
Nov 21, 2020 at 4:57 PM
DEANNA MCCOY
Fuel pressure was in range, so fuel pump was good. I replaced all 8 injectors, started it up and took it down the road about a mile and now it sounds like it's misfiring on about w cylinders, and nothing on my instrument panel works.
Mar 20, 2021 at 6:45 PM
DANNY L
  • 5,648 POSTS
Hello again.
So, you were able to get the truck started? You mentioned it feels like it has a multiple cylinder misfire. With this happening did it turn the check engine light on and set a diagnostic code? I would suggest having a CAN scan performed. It will test all the systems on your truck for fault codes including misfires. Here is a tutorial showing what is involved for a CAN scan:
Once you have this done get back to us with any code information and when can continue to diagnose these issues. Hope this helps and thanks again for using 2CarPros.
Danny-
Mar 22, 2021 at 1:45 AM
