Cranks good, intermittent no start
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
WAREHAMSFARM
Starts the stalls immediately then wont start again for a few tries. Cranks strong new battery I cleaned the fuel pump screen filter and polished the spark plugs also added stop fuel injection cleaner. I listened to the injectors they all sound the same. Once car is running it's fine.
Mar 24, 2021 at 5:26 AM
This does sound like a fuel issue so even though you cleaned the screen, we still need to know what the pressure is that it is supplying.
https://www.2carpros.com/articles/stall-at-idle
You PSI should be almost 50 so let's check the pressure and go from there. Below is the spec from the manual.
Thanks
Mar 25, 2021 at 5:15 AM
