I started my car fifteen seconds.later it shut off,now cranks/no start. so I started with fuel I turned the key to on two to three times to listen for fuel pump/good. I opened the Schrader valve/push in stem/gas dribbles out/no pressure/I took off fuel filter/fuel regulator it was clogged/ I blew through it really hard and dirty dirty gas came out/so I put a new one in/cycled key three more times/checked Schrader valve pushed stem/i' am glad I had on safety glasses/lots of pressure. i did not have a fuel pressure tester/or the money to buy one. tried to start/cranks/no start/I used a little starter fluid two to three times/same thing. check for spark next? is there a way to check it without removing coil rail and buying the special grounding set of wires/help/advice/please/no money.
left/theres no dtc codes/I have scanners/meters/test light
I was going to test and clean the injectors/but would not the car start with the started fluid?
Feb 10, 2017 at 12:53 PM
