Cranks but will not turn over, no spark no fuel
1991 MITSUBISHI DELICA
249 MILES • MANUAL
ZANTANA TONIHI
So I did an engine swap and and everything else including dash everything was working fine before the swap. it is now in a econovan. have checked relays, ECU, spark plugs fuel pump and pressure fuses battery. any ideas I can check next? it's like there is no power but it turns on cranks but wont a start. could it be wiring somewhere? also has had a manual conversion. but note it was working before the engine swap. any help or ideas? thanks
Nov 28, 2019 at 6:20 AM
  • 110,244 POSTS
First, please understand this vehicle isn't offered in the US, so my technical information is very limited.
When you say there is no spark or fuel but everything worked prior, the first thing that comes to mind is an automatic shut down relay. . Does this vehicle have one?
Nov 28, 2019 at 11:40 AM
