Cranks but will not start completely
166,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RHA010
So my vehicle was driving perfectly fine one day the next morning i went to start it and it wouldn't turn over but it would crank. At this point when i try to start it it will turn over just barely and then shut off again so as of right now it doesn't drive and I have maybe about a 1/4 of a tank in so just below the first fuel line. I have been told I might need to change my spark plugs but i am not sure just want to know your opinion on it all the electrical works without any issues as well and the check engine light is on.
Apr 27, 2019 at 10:25 AM
Good morning,
You need spark, fuel and compression for the engine to run.
Can you hear the fuel pump run when you turn on the key?
Does the tachometer move up a little while cranking?
Apr 27, 2019 at 10:35 PM
