Cranks but wont start after hot
194,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
DAN MATTHEWS
When the engine is warm and you park it for fifteen or twenty minutes try and start it it cranks but will not start. I already changed ignition coil and crankshaft sensor it still does not work.
Dec 20, 2016 at 7:07 AM
LOU P
  • 118 POSTS
Hello, you need to spray starter fluid to see if the car will fire and start, that will tell you if its a fuel or spark issue. if it starts then I would suspect a fuel pump issue.
Feb 17, 2017 at 7:05 AM
