Cranks but will not start
100,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
81SCOTTSDALE
I just finished replacing a faulty starter. it would kick the starter out over and over then finally catch and start so I put a new starter on. now it turns over but will not start.
Feb 24, 2019 at 3:50 AM
  • 110,251 POSTS
A few things can cause this to happen. First, I need you to read through this link. It discusses the most common causes of a crank no start condition.
If it ran prior to replacing the starter, my guess is the problem is electrical. Do me a favor. See if it will start with starting fluid, even for a couple seconds. If it does, the problem is fuel related, but if it doesn't, then it is ignition related (no spark to plugs).
Here are a couple links you may find helpful:
Let me know what you find.
Feb 24, 2019 at 9:48 AM
