Cranks but will not start
98,000 MILES • 1.8L • 4 CYL • AUTOMATIC
MYRA NUCKOLS
Car getting fuel, have replaced spark plugs, throttle body, throttle body sensor, camshaft sensor and coils. starts two or three times after each new part then wont start again.
Jun 28, 2019 at 3:49 AM
  • 55,746 POSTS
When it wont start will it run on starting fluid? It sounds like the crankshaft sensor is going out. We need to run the codes to see what comes up.
and
Jun 29, 2019 at 12:38 PM
MYRA NUCKOLS
changed that too.
Jun 29, 2019 at 12:42 PM
  • 55,746 POSTS
Okay, does it run on starting fluid? Also if you turn the ignition key to the on position without cranking the engine over do you hear the fuel pump run in the tank?
Jun 30, 2019 at 3:02 AM
