Cranks but will not start
190,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ROB PRICE2
My car shut off while driving down the road. The throttle cable broke so I thought it was that, replaced it and only cranks. So I took the cover off over spark plugs and see there was oil all around them realized I needed a new valve cover gasket, so got that plugs and wires soaked up all the oil around the plugs. Then changed everything after that still would only crank. I checked fuel pump and that is fine. I have compression but not sure if it is getting a spark or if my battery not getting enough juice. The battery light always on. Any help would be appreciated thanks in advance.
Robert
Jul 21, 2018 at 2:50 AM
  • 110,251 POSTS
If you are getting fuel and have good compression, chances are it is related to ignition spark to the plugs. Here is a link that describes how to check for spark. Do this and let me know what you find.
I hope this is helpful. I will watch for your reply.
Jul 21, 2018 at 2:49 PM
