Cranks but will not start
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAUL SHARSHEL
Car cranks but will not fire. All fuses are good, fuel pump is working, I have fuel pressure from the rail. There is a clicking noise conning from the EGR valve and also a whining noise coming from the throttle. When I unplug the throttle, the noise goes away.
Jan 23, 2018 at 1:02 AM
  • 55,766 POSTS
It sounds like you lost ignition can you confirm by checking for spark use this guide.
Please run this test and get back to us.
Cheers, Ken
Jan 24, 2018 at 5:14 AM
