Cranks but won't start
104,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
RETIRED 1
Originally would start after long cranking, problem got progressively worse. Now will not start at all. No spark and no injector spray. Have replaced ICM, rotor, cap, fuel pump relay. When it did start it was fine rest of the day but after sitting overnight back to no start. Hard start was accompanied by backfire when finally firing. I also disconnected fuel line at filter and turned ignition on to test fuel pump. It seems to be pumping fine.
Apr 17, 2019 at 11:01 AM
  • 55,748 POSTS
This sounds like a classic fuel pump problem. To be sure here is a guide to help us check the fuel pressure. Ignition ON Engine OFF 62-90 kPa (9-13 psi).
This guide can help as well:
I have seen the coolant sensor cause this as well. Please run down these guides and report back.
Apr 19, 2019 at 5:04 AM
